How to hide (delete) or set left blocks in product category page for Newspaper SHOP KIDS STORE theme? Thanks
Here is the pic
https://imgbb.com/yXP4w1Q
This topic was modified 2 years by
jackzhu.
Those are filters; you can delete them with right-click or change the type of the button of the filter.
Thanks for your replying. On a page, I did not find tagDiv Composer like the left in the picure https://postimg.cc/r0Lz5rWb
It seems i found the tagDiv Composer on the page, but it shows me 404 when i clicked it
https://postimg.cc/62WsnWjw
Please update the theme to the latest version, 12.6.5. It seems that you have an older version.
I recommend that you update the theme manually https://forum.tagdiv.com/how-to-update-the-theme-2/ via FTP/cPanel/File Manager, also if possible disable extra plugins during the theme update to avoid any problems that may arise and make sure that you have activated the tagDiv Standard pack plugin to keep the website’s look. You can try to update the theme on a staging website.
After you update the theme, you need to update the theme plugins too.
In the worst cases, the settings in the theme panel may be lost (there have been isolated cases), in these cases, after the theme plugins that were previously used are activated, you will have to use a backup for the theme panel -> https://forum.tagdiv.com/import-export-theme-settings/
