How to improve page speed
I already applied all the part which is given in the tutorial but still can’t able to get good page speed score. Also is there any way that we can add facebook comment. please check http://www.wackyy.com and suggest me.
Also I am using smart list 7 on some of my post. In this, the social sharing toolbox not visible and also tell me how to deactivate light box of image in smart list 7 type post.
I want both facebook and disqus comments.
  • This topic was modified 10 years by techlive.
Check your site using google’s PageSpeed Insights: https://developers.google.com/speed/pagespeed/insights/ and check online or use our instructions as solutions based on their notifications.
Also make sure you go trough our server/host requires and recommendations: https://forum.tagdiv.com/requirements-for-newspaper/
Our page speed guide and covered the most important aspects that google notifies you of and based on which it classifies and grades your site’ regarding speed. The theme has been developed to be fast but it may still need configurations on this matters so test your site using google’s page speed insights testing tool and make sure you follow the guide instructions and methods then test your site again.
We can’t offer speed customization services at the moment so if you still need guidance on this or you’re not aware of the steps you need to take in this regard please consider hiring a developer or a freelancer to do this for you.
The fb comments plugin should appear by default on your post pages. Where do you want to add it? Please let us know and provide more details on this!
The smart list 7 lightbox image can’t be disabled just for the smart list 7 images only if you disable it from theme’s panel > post settings globally: http://screencast.com/t/pIg0TBAqCSsE
Please provide more details about the configuration you want for the fb and disqus comments.
Hope this helps!
  • This reply was modified 10 years by Lucian.
Hi, Thanks for your reply
Another question is, I am using smart list 7 on some of my post. In this, the social sharing toolbox (on top left side hover image) not visible and also tell me how to deactivate light box of image in smart list 7 type post.
I have update my previous post because I have forgotten to answer to your other two questions. Theme’s socials are available on theme’s smart list 7 templates so I’m not sure what you mean: http://screencast.com/t/qRp5y2UuFUvt Please provide an image is possible and a link to a post on which you experience this issue.
I have disable that setting but still image opens in light box
You can see the social sharing toolbox on top left side in the below link on hover image
http://www.wackyy.com/awesome-biggest-santa-of-the-day/
while not visible in below link
http://www.wackyy.com/funny-pictures-of-the-year/
Also let me know is it possible to Ad after content in smart list 7
  • This reply was modified 10 years by techlive.
The smartlists have the modal image activated automatically from the code so in order to remove this you will need to edit the theme files like so: http://screencast.com/t/8IBr8aD4z9gV
As for the second part of the question, please provide more details so we can better understand your request.
Hi, Thanks for reply.
As you can see that there is ad below title that’s ok. The problem is there is only one ad in content area. I want to add another AD below content just above the TAGS in the post type of Smart List 7. Is it possible to add advertisement just above the tags?
Hello techlive,
If you want to add another ad just above the tags into your smart list post, you have to use do_shortcode method with the custom ad. To display the ad in the desired place, first of all, you should insert your ad code in Custom Ad, like this: http://screencast.com/t/oasFD3Txm and then you have to alter td_smart_list_7.php file like this: http://screencast.com/t/cdohMstuIIc and the result you should see here: http://screencast.com/t/oQx6739Ad
The code is here -> http://pastebin.com/LNTtgU0y
Thank you for the message!
Thanks for your help.
Now can you please guide me how to add facebook comment just above the disqus comment. I want to add fb comment, the plugin not works well so how to add in other way.
Regarding the facebook comments plugin, you can add it in a custom location by following this guide here: https://forum.tagdiv.com/topic/using-facebook-comments-plugin-and-changing-the-default-location/
I hope this helps.
