How to manually sort posts?
How can i manually choose which posts show where? And in the mega menu, how can I manually sort them there as well? Thanks!
David
I doubt the theme has that option. You’d require a plugin like this https://wordpress.org/plugins/wp-hide-post/ (but be aware it is not among the recommended plugins that are tested with the theme.)
These are all the block settings currently available in the theme
https://forum.tagdiv.com/block-settings-tutorial/
Choose from the mentioned filtering and sorting options. Enter post IDs in the filer tab if you want specific posts to be shown.
The mega-menu does not have sorting options, this is how it can be created
https://forum.tagdiv.com/mega-menu/
Thanks! Your support rocks! I am going to look at your other theme as well, just based on your wonderful and timely support. Have a great day.
@dlr720 I thought you were talking about the homepage (showing latest posts). Sorry about my previous comment.
