How to move comments box to appear below each post
I need help with my site https://popa.com.br/.
The comments section appears below the “ARTIGOS RELACIONADO(related Posts)” section. I want to move the comments section directly below each post. Since I am a newbie, I would really appreciate your help.
The current layout is a real problem specially if readers open the posts/page on mobile phones.
Thanks in advance!
The page I need help with: https://popa.com.br/
You can see post example at https://popa.com.br/inversao-dos-polos-magneticos-da-terra-pode-ocorrer-mais-rapido-do-que-o-previsto/
If you use the predefined post templates, that could only be done with modifications in the theme post template files
https://forum.tagdiv.com/topic/post-comments-directly-under-post/
However with the new cloud library plugin and tagDiv composer, this is a matter of drag and drop. You can design your own post templates, also import from beautiful templates created by us.
So for example the comments can be simply dragged in the position you want
https://www.screencast.com/t/7kR190pUlu
https://forum.tagdiv.com/tagdiv-cloud-library-plugin/
