How to shift Trending now box to left
I have to shift the black box with trending now towards left so that the red portion at the left of this box does not appear.
Please guide how to do this.
A screenshot is here for your reference.
http://www.screencast.com/t/E04S5EMFXw
Thanks for your help
Please add this css in Newspaper>Theme panel>Custom code>Custom css
.td-trending-now-wrapper{
padding-left: 24px;
Hey, buddy. How are you? Could you pls help with how I can change the background of the “Trending Now”?
You need to use tagDiv Composer, select the “Trending Now” change from general to Style and look for the “Title background color” https://www.screencast.com/t/RWWpyGF1
Hope this will help you.
Hey, Calin; how are you?
I tried adding the code you provided to it’s place, unknowing I added it to html section instead. In the end, I the code is now appearing after the subfooter. I went back to the html section to remove it but it’s no longer there. Here’s the url but https://newsfrigate.com/ the site is set on coming soon mode.
Best wishes
  • This reply was modified 7 years by wwsurfers.
Unfortunately I can not check your website because is in coming soon mode
Please make sure that you have the latest theme version and all requirements are proper set -> https://forum.tagdiv.com/requirements-for-newspaper/
