hi,
when I activate the mobile theme plugin, I get this message
Fatal error: Class ‘td_style’ not found in /home/xxxx/xxxxx.com/public_html/wp-content/plugins/td-composer/td-multi-purpose/styles/tds_title/tds_title2.php on line 9
I check this code Line9,
class tds_title2 extends td_style {
It seems td_style class is missing. How can I fix this issue??
Please make sure that you do not have a plugin conflict, please deactivate all non theme plugins, also if you are using child theme or cache plugin, please deactivate them, clear all cache and try again.
If the problem is still there, please delete( delete the theme plugins too, do not override ) the current version of Newspaper that you have and download again from themefores the newspaper and reinstall it.
If the problem is not solved, please send us an email at contact@tagdiv.com and provide admin login. We will take a look. Include a link to this topic in the email.
Unfortunately, the Rank Math plugin has not been tested with our theme and therefore, we cannot say for sure if it will work or not as expected with the theme, sorry! Also, we cannot provide support for untested plugins.
This is our list with tested plugins with our theme -> https://www.screencast.com/t/cmPkh9jba4sZ
