How to Speed My Website by 100/100 on Google Speed Test
Hi!
i am using all the recommended plugins https://imgur.com/1FNfqEy
I am uploading featured image full dimension size (1068×710).
Image size lower than 50 kb (after compressed).
Activated cdn as mentioned in tutorial.
i completed all step- as mentioned on this “link”
1. Enabling Gzip compression
2. Set the Leverage Browser Caching
3. Optimize images
4. Use a cache plugin (WP Super Cache)
5. Plugin Load Optimization (not finished yet)
6. Removing Emojis
7. Removing other scripts
8. Remove Scripts by Jetpack
9. Mobile theme optimization
10. Preload Newspaper fonts
now i tested page speed. see the screenshots.
Please let me know how may i fix these below mentioned issues.
Desktop Test https://imgur.com/8mVvXuN
issues –
1. Eliminate render-blocking resources (very important)
2. Reduce unused CSS (very important)
3. Avoid an excessive DOM size (very important)
Mobile Test https://imgur.com/CgoHQpN
issues –
3. Properly size images
4. Reduce unused JavaScript (very important)
5. Ensure text remains visible during webfont load (very important)
Also tell me what dimension of image exactly i need to use as featured image and then i will regenerate them.
and how much kb/mb size of a featured image is best for image optimization.
Thank you so much.
i love to learn. so help me by the tutorial.
my websites mybdtech
  • This topic was modified 5 years by rirakond.
I see that you solved the majority of the issues and you have a great score in Google Pagespeed Insights. My recommendation is to check the tutorials from those platforms gt metrix and Google Pagespeed Insights and I’m sure you can increase the page speed.
Our developers are working a lot to improve the page speed in every update.
So, please make sure you use the latest update of the theme and plugins because it may help you for your page speed.
Also, to increase the page speed you can check these similar topics for more solutions:
– https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/
– https://forum.tagdiv.com/topic/a-few-tips-for-newspaper-x-speed-high-cpu-usage-issues/
– https://tagdiv.com/how-to-increase-page-loading-speed/
– https://developers.google.com/speed/docs/insights/v5/about
– https://forum.tagdiv.com/topic/adminpanel-slow-td-composer-query-string/
