how to speed up themesmag
what are optimal settings for underpowered server?
My server is running very slow on loads average of 40. it’s unusable.2Ghz cpu and 4GB ram seems not to be enough, very few plugins too. Please advise.
Did you change the default memory allocated to WP in your wp-config.php file ?
Did you check a post page at GTmetrix.com to make sure you have proper gzip/deflate running as well as expiration headers, consider using a caching plugin for site?
Hi @nicoblog
First make sure that the server meet the requirements for our theme: https://forum.tagdiv.com/newsmag-requirements-for-newsmag/
In terms of speed we have made a page speed guide and covered the most important aspects that google notifies you of (image optimization, js/css render blocking and more..) and based on which it classifies and grades your site’ regarding speed. You can find it here: https://forum.tagdiv.com/how-to-make-the-site-faster/ Also you may find some useful information here: https://forum.tagdiv.com/topic/website-memory-problem/
Hope this help.
Thanks i’ll move to a dedicated server my VPS even with 4GB can’t seem to take the load.
Have you followed the instructions from our page-speed documentation and the the server is still overloaded? Please provide your site url so I can take a closer look.
Note that w can’t offer page-speed customiztions, we can only guide you in the right direction but you are the one that has to do the adjustments. The theme is tested and optimized to work an every server but there are many aspects which can influence your page speed. On the forum are many topics regarding the page sped so you can do a search for more details about this.
The problem wasn’t on newsmag code it was the vps fault, now it’s working fast.
