HTTPS not prober working.
Hi folks,
I change the whole site all to https.
But the demo advertising link is still in the template and thats in http
How can i remove them?
Greetings
Fredi
Hi SPAREGmbH,
If you refer at this: https://www.screencast.com/t/60Wrjj19PiG
That is an ad, please read about it here.
Hi Calin,
Thanks for the Reply.
Sorry that is in your Template. I cant deactivate that. But i have to because thats Hardcoded in your Template. I copyed the Link belowe. Is it possible to remote that Link from your template over the settings?
Thank Calin,
It works i have to remove the Link. Only to deactivate the Option din’t remove the link from the template.
You can close the Ticket. Thanks
