https://www.hindinewsupdate.com/category/architecture/?amp now work please help
Tag ‘html’ marked with attribute ‘data-ampdevmode’. Validator will suppress errors regarding any other tag with this attribute. Debug.
bottom line showing exit mobile version
amp url ?amp=1 “=1” why?????
reinstall and then amp validation problem solved but amp-mobile-version-switcher dose not remove please help fast….
please check this screenshot https://www.screencast.com/t/lWMFczbRy
Hello !
At the moment AMP is not active or set up properly on your website as you can see in our guide: https://forum.tagdiv.com/tagdiv-amp-plugin-tutorial/
Please note that at the moment the Support team is not 24/7 available. Please note that we answer the topics from Latest to Newest Monday – Friday from 08:00AM to 05:00PM GMT+2 So multiple replies to your topic will only make us to get harder to your topic.
ok now please check this screenshot https://www.screencast.com/t/lWMFczbRy
how remove bottom line showing ‘exit mobile version’ and how change amp url example remove this ‘?’ simbol and this ‘=1’ simbol.
please solve this problem
https://www.screencast.com/t/gH0DJWMGXpAZ
Hello !
The plugin is moving away from any use of /amp/ in favor of ?amp because it allows for an AMP version to be used for every URL, without conflicting with other rewrite endpoints added by WordPress. The query var ?amp and the endpoint /amp/ are functionally the same, and there should be no difference in terms of SEO. (There used to be an SEO reason against it in the past, but this has not been the case for some time.) This cannot be changed.
For the exit mobile button please use this css code: #amp-mobile-version-switcher {
display:none;
This code must be inserted here: https://www.screencast.com/t/ahwdwZk93
thank you so much sir.
this is fix it. https://www.screencast.com/t/jmBqhezL
