HUGE PROBLEM – PHP Warning: Illegal string offset
My hosting is providing those erros related with your theme.
It’s causing critical erros:
PHP Warning: Illegal string offset ‘td-multipurpose’ in /var/web/site/public_html/wp-content/plugins/td-composer/legacy/common/wp_booster/td_util.php on line 646
PHP Warning: Illegal string offset ‘td-multipurpose’ in /var/web/site/public_html/wp-content/plugins/td-composer/legacy/common/wp_booster/td_util.php on line 1230
PHP Warning: Illegal string offset ‘portrait’ in /var/web/site/public_html/wp-content/plugins/td-composer/legacy/common/wp_booster/td_util.php on line 3016
PHP Warning: Illegal string offset ‘weight’ in /var/web/site/public_html/wp-content/plugins/td-composer/legacy/common/wp_booster/td_util.php on line 3013
Hello !
Please make sure that you have accomplished all the system requirements as in our documentation here: https://forum.tagdiv.com/requirements-for-newspaper/
1- I’ve all requirements in green – newspaper system status
2- I’ve already tried to deactivated all plugins except tagdiv ones.
Please I need real support.
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
Hi @Tribiker, were you able to get this resolved? Dealing with the same issue.
Hello @villagesnews !
Please use the informations above and send us an e-mail.
Our team will have a look.
