hugh problems after updating
Hi there, I need some help. After updating to 12 my homepage was completely a mess and went back to 9,8. Not a great solution because my homepage was again gone. Blogs are ok but I don’t know what to do now?
http://www.stressplein.nl
usually best to update via ftp
Before the update make sure you have a full backup, after the theme is updated please make sure that also the theme plugins are all updated. Make sure that the tagDiv Standard pack plugin will also be installed (this can be installed from Newspaper > plugins), when everything is updated, make sure that you clean all cache, object cache and purge CDN.
Hello Calin, Cannot find this plugin, tagDiv Standard pack plugin. All others are ok. My homepage is a mess and the other pages are ok, for so far i know.
I think it has something to do with a template error or so,
The plugin can be installed and activate from Newspaper > plugins – https://i.imgur.com/icpurCE.png
Hello Calin, just updated everything to 12 and installes the plugin. Still everything is a mess, it seems that the templates are not used as in the old version
Could you please clear all cache and disable it afterward? And recheck the website, or disable the options for css, js and make sure all cache is cleared.
I’ve checked the website, and some elements are not displaying correctly due to cached CSS and JS files from the theme.
Hi I just cleared all cache and disabled litespeed cache plugin, it’s still the same
Please make a full backup and contact us via email at contact@tagdiv.com and provide temporary wp-admin and cPanel access. Include the link to this topic to identify you faster.
