I am not able to add widgets in my footer section
Hello I am not able to add widgets in my footer section whatever changes I make it won’t show
site : https://www.animemedia.net/
Please let me know what template is used for the footer (standard template or cloud template).
If you have a cloud template you can add blocks with tagDiv Composer in footer => https://i.imgur.com/rKOYnqG.png
If you have a standard template, you need to set a template => https://i.imgur.com/3dkmkP4.png and add block in Appearance -> Widgets and set the blocks in footer 1,2, 3 https://www.screencast.com/t/o5jsJ01pwJ -> https://www.screencast.com/t/S2JwbQpbq3K
Hello I am using cloud template and I tried the following steps yet I am not able to add the widget
So, if you have a cloud template you can add like in this video the blocks => https://www.screencast.com/t/oHlMn8zmP
How do I add newsletter Shortcode in Footer Section is it possible to do via flexbox?
I don’t really understand what you mean by “flexbox”, but yes, you can add the newsletter in the footer section or you can import a footer template that has the newsletter =>https://i.imgur.com/cD592OF.png
hello, I tried doing that. It is showing me this
Newsletter form code is empty. Please configure this block/widget by entering a form code
https://imgur.com/a/8EhRRCk
Maybe that plugin which you use it is not compatible with our theme, that’s why it’s not working.
Hello, which plugin shall I use. Rn I am using MailChimp
Please make sure that you have followed all the steps as you can see here: https://forum.tagdiv.com/the-newsletter-plugin/ Also from version 11.2 our team has developed our own Newsletter plugin which can be integrated using tagDiv Composer as you can see here: https://forum.tagdiv.com/tagdiv-opt-in-builder/
You can choose on 1 which fits you the most.
