Number 1: An error occurred and we could not finish the process.
https://prnt.sc/vfgug9
Number 2: When I upload plugs manually tagDiv Composer is not working properly
https://prnt.sc/vfgvpl
https://prnt.sc/vfgw04
When I try to delete something it became black and nothing works
Hello !
Please send us a screenshot of your System Status Tab and make sure that all the requirements are met as you can see here: https://forum.tagdiv.com/requirements-for-newspaper/ ; You will have to first start looking for a plugin conflict. please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also you can try and remove and re-install the tagDiv Composer plugin.
Let us know the results.
