I have a few questions and or problems
Hi Im having a few problems –
#1 Using Block 5 in a 1/2 + 1/4 + 1/4 row – in th 1/2 block
Im getting a huge gap between the feature image and the title.
(see image i am sending)
#2 The crop on a feature image when it it is in a 1/4 column
is not favoring top – center. it seems top-left.
(see image)
#3 displaying a page of post based on a Tag I want to choose a different
template. I’m I just not finding this? (see image)
#4 Can I resize a video in the body of a post? I have inserted a Youtube
video and I want it to display smaller on the post page.
see problems at this link
  • This topic was modified 10 years by rfdempsey.
I forgot to give you the url
http://icapeace.wpengine.com
Bob
Theme’s blocks we’re designed to work on 1/1, 1/3 and 23 columns: http://screencast.com/t/fN3T2xPSwV We didn’t tested 1/2 or 1/4 layout and there is no implementation for it, sorry.
You can filter posts by tag using wither post loop settings if you’re using page-builder+latest as page template: http://screencast.com/t/5otlX0agNtVp or from block settings for the content displayed with Visual Composer: http://screencast.com/t/FhVMFdsdoo
For more detail about page templates and block settings please refer to our documentation:
https://forum.tagdiv.com/page-templates-2/ – https://forum.tagdiv.com/block-settings-tutorial/
You can use the embed code and change the values for width and height as you want, here is an example: http://screencast.com/t/izfEUcYf296Y – http://screencast.com/t/ERGYIvyrF
