I have a problem with mobile theme
Good day
I a have problem with te vizualization of mi blog in the mobile.
In PC the theme works fine.
In Pc Browser
But in Mobile works bad, the font and theme in General is deformed
In Mobile
Regards
  • This topic was modified 5 months by ivandyk.
That looks quite bad. I see you activated the AMP plugin, was it by mistake or do you want to use it?
If you want to use it, we recommend using it together with our mobile theme https://forum.tagdiv.com/tagdiv-amp-plugin-tutorial/ The website won’t look broken but there will be a simpler layout and design than on desktop.
Or if you don’t want to use AMP and you just want the same content and design from desktop to be displayed on mobile, then please deactivate the AMP plugin -> https://prnt.sc/tWg2bFmrtRgZ
