1. The issue is from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
2. Please note that customization is not covered by the support team: https://forum.tagdiv.com/newspaper-theme-support/
For customization and other services you can contact our custom work team here: https://tagdiv.com/premium-customization-services/
Thank you. Got them fixed! you are the best!!
Reply here: And could you please tell me how to make them theme full width. All the other theme service provide width adjustment. How to make the website full width?
There is a workaround: Edit the page with TagDiv Composer, then click the row of the element, and set up also the row like stretch row, check this screenshot: https://www.screencast.com/t/hyifvDejBc3W
Please note that you need to use a cloud/PRO template to have this feature. Otherwise, if you use a default one, then this will require custom work which is not covered by the support team.
Thank you for understanding!
