I have problem
Good evening,
I have a problem with the issue I have agorasei.opos will see in the attached I want to remove titles and add other than that and how to do this?
http://csrnews.gr/Untitled-1.jpg
Hello nasosrogas,
The titles you mention are category titles. i have already answered this question here: https://forum.tagdiv.com/topic/categarory-headers/
If this is not what you mean, provide us with more details.
Thank you
Good evening, what shows me changing the headline I am interested per change the rest, as you show in the attached http://csrnews.gr/Untitled-1.jpg
Hello nasosrogas,
As you can see from the other topic, the titles you are pointing out are category titles. They are the categories you created and named. They can be edited here: http://screencast.com/t/cKbsVOZg
ant then change their title like so: http://screencast.com/t/Pc3QOnMiFD
You can also control what categories can be shown here by adding the category ID here: http://screencast.com/t/72QfT1Ff then http://screencast.com/t/E8cWlO4lk.
There is also a block settings tutorial in our Documentation. https://forum.tagdiv.com/block-settings-tutorial/
* If you want to display something other than categories in that menu, that is a custom job and has to be modified in the theme’s code. There is no easy option for that at the moment.
I hope this helps.
good evening, from what php change these?
INTERESTED in each menu to put me what you want is another way;
Hello nasosrogas,
If you want to change those titles there are 4 possibilities : http://screencast.com/t/8pcwth6xhkz
Categories, tags, authors or featured/popular posts. If you want one of these you can select and customize them from block settings. Please read the documentation: https://forum.tagdiv.com/block-settings-tutorial/ and look for ajax filters.
If this is not how you want to modify them and you want something other than these 4 types of filters, you have to modify the td_block_*.php found here: http://screencast.com/t/m3gZhQ4mam and also td_config.php found in newspaper/includes/
I hope this clears things up.
I first want to thank you to jumpstart your answers, the service is too kali.Omos, I have the following item in each category I want to add any ego category I and the next not appear the same but different categories. Can be realized that from you? Has cost? If what is what;
Just another tip on categories: you can select what categories to display from the ajax filter by using their id’s like so: http://screencast.com/t/cK6WFSp7Pu. You enter the id’s separated by comma ( , ) . You can get category id’s like so: http://screencast.com/t/Bubwxqn3H
I don’t seem to understand exactly what it is you want help with, but i am guessing you need some custom work done. Unfortunately we cannot offer any custom work at the moment, as we work hard on the development, updates, fixes and support. You can always get a freelancer from sites like: http://studio.envato.com/
Thank you for your message.
Good evening,
the problem has been solved, even though I have 2 issues
1.Where categories the word .the problem I have is that the Greek show as more highly instead that the more I change it?
2.The categories displaying want to enter in the order I want and not as it automatically takes what you can change;
I continue to say again that your service is flawless
thank you
Hello nasosrogas,
I’m really struggling to understand your English,
1.) Please provide more details as i cannot understand what you mean. Provide a link to your site and a screen capture if you can please.
2.) You can follow this link to our forum, this issue was already answered by Alin: https://forum.tagdiv.com/topic/can-i-reorder-ajax-dropdown-on-my-own/
Dear Newspaper theme development team,
We are facing a problem trying to set up the footer in our new site, using
your template. As you can see in the following screenshots, we are getting
different visual results between Chrome and Firefox browsers (for example we
choose footer template number 8).
In Firefox, everything works as it should be,
http://csrnews.gr/image003.png
http://csrnews.gr/image004.png
but in Chrome keeping the same settings, we see the following
As you can see, a big part of the main footer is missing, and we cannot see
also the sub-footer. We tried to change footer templates, we used several
computers with different operating systems and configuration, but the
problem is the same everywhere. It seems that Chrome (we examine the page
source code), is not capable of interpreting the template code correctly.
We would like your help in order to be able to fix this problem, as you have
helped as a lot in the past days.
Thanks in advance,
Best Regards
Hi nasosrogas,
I cannot access your site – http://screencast.com/t/0mOvxD8rNY it seems to be in the maintenance mode.
Please also disable all your plugins except of Visual Composer to make sure that it is not a plugin conflict, also clear cache and purge your files if you use CDN. Let me know if you still have this issue and when I can access your site to take a look.
