I have problems visualizing the images
Hello Videnciastral,
I have checked your website and I saw that you are using a lot of untested plugins which can interact with the theme core files and cause a lot of unknown issues. Try to disable all of these, leave just Visual composer to active, clear all your caches and install only the plugins that come bundled with the theme packet and rule out any conflicting plugins.
If you do not have any access to load media in your media library, please make sure that you have set them all the permissions for upload folder in your Cpanel/FTP. Also, check your system status parameters to be higher increased according to our documentation here -> https://forum.tagdiv.com/system-status-parameters-guide/
Also, if the problem is still there, please try to make a new clean install from scratch via FTP and check the results.
Good afternoon,
I answer him:
I have not installed any plugin that comes by default in the template configuration.
I do not have any cache component in wordpress.
Please can you help me?
Also I try to activate Visual Composer and I could not. Attachment Screen Capture
https://drive.google.com/file/d/0ByMa6xO4xXEMTEMxZG5oVEZrVUE/view?usp=sharing
Thanks!!
You cannot open a ticket to Visual Composer staff because this type of plugin come bundled with our theme, and it is built-in with our theme. If you want to have access to plugin support, you should buy it, but it is unnecessary this thing. If you have some troubles with this plugin in our theme, please ask them, and we will be glad to help you.
I am having problems with the visualization of the images in different devices and browsers from the front of the web and you are not giving me solution.
Can you help me?
Hello videnciastral,
I have inspected your website for many browsers and I did not saw any problems with your images, as you can see here -> https://www.screencast.com/t/hYOjjFRP7 Also, I have checked your website on Safari (MAC) and I noticed that you have some problems with all your images which has strange symbols as you can see here -> https://www.screencast.com/t/kENf1zGB2ZPn If you want to avoid this problem you should rename all your images which have these symbols because the Safari browsers will interpret in other way and your URL will be break and that’s why you bring these errors, sorry!
Thank you very much, it is already solved.
Now I have doubts about how to configure the mobile template. I have installed the plugin tagdiv the mobile theme. But I want to customize the presentation of the Home with Visual Composer. This is possible??
Thanks!!!
Unfortunately it is not possible as the mobile theme will convert your homepage to a predefined one. Please read this guide: https://forum.tagdiv.com/the-mobile-theme/
