i have problems
1_the slier Does not appear when browsing from the mobile
2_ARTICLE INLINE AD not working
Hello !
Please provide a link to your website in order to inspect and also make a screenshot of your inline ad settings.
Hello !
Mobile theme has a different non-editable design. The Mobile theme was specially designed for optimization on mobile devices. Unfortunately on mobile theme you cannot do much changes of design. If you want to have the same design as on desktop mode you can achieve that by simply disabling the mobile theme. So you will have to recreate your page in the Mobile Editor at the bottom of your page editor : https://www.screencast.com/t/tvLnK0Ae.
You can disable the mobile theme on certain pages if you want by going here: https://www.screencast.com/t/HgVM9URqqIEa
You can find out more about the Mobile Theme options here: https://forum.tagdiv.com/the-mobile-theme/
thanx for this information, but there is problem i want to solve
>>>>>(ARTICLE INLINE AD not working on desktop)<<<<<
Hello !
Please make sure that you have set a paragraph for the inline add, also please post a screenshot with your inline ad settings.
Hello !
Please take a look at this picture: https://www.screencast.com/t/0SLCz8u12xJ5 You have to set where you want your Ad to appear, like after 2 or 3 paragraphs.
