I just start a new business (blogging) and i bought a newspaper theme. do I need a home page? why none of my article not showing to the home page? do I need to create a blog page? or just post directly to the category posts?
best regards
So if you start a new website (blogging) then yes, you should have an homepage or a blog page, you can choose one of these from Settings > Reading -> https://i.imgur.com/ZAncfBo.png
Using a blog page you will show the latest articles, also you can choose the article layout from theme panel -> https://i.imgur.com/MdaYgk1.png
Homepage – How to build and set it -> https://forum.tagdiv.com/homepage-how-to-build-and-set-it/
If you do not want to build your own homepage, then you can import it from tagDiv Cloud Library or use a demo .
If you have other questions, just let me know!
