I need WPBakery to work again.
I bought this theme thinking that WPBakery Composer worked with it but it doesn’t!
I use it to have 6 columns and Full Width on posts. But:
  • As soon as I activate TagDiv Composer, WPBakery Composer stops working properly (no more full width, limited columns…)
  • If I deactivate TagDiv Composer in order to make WPBakery Composer work again, I get “wp_booster errors” and the website’s header doesn’t load anymore…
How can I get rid of the errors? Or get full width on articles and 6 columns with TagDiv?
I’m wasting so many hours on this. Please help.
Hello Tsedaka,
Sorry for this inconvenience but please notice that we do not recommend using the Visual Composer plugin for 6 columns, unfortunately! Where do you see this recommendation at our documentation? If you will deeply check our useful guide and documentation, you will see that our recommendation is to use Visual Composer only for pages and for 3 columns, as you can see here -> https://forum.tagdiv.com/newsmag-how-to-use-visual-composer/ Notice that the Visual Composer has not been tested for post pages, sorry! Regarding post pages, please check here -> https://forum.tagdiv.com/newsmag-post-formats-for-tinymce/ Also, for more information about the transition between Visual Composer and TD Composer you should read the following guide from here -> https://forum.tagdiv.com/visual-composer-tagdiv-composer-transition/
Regarding your received errors, please provide more details and some useful screenshots together with your website so we can identify them.
Also, if you are unsatisfied with our product and if you want your money back, please make a full refund here -> https://themeforest.net/refund_requests/new and we will get your money back as soon as possible.
