Image elements explicit width/height Issue (Page Speed Insight) on desktop
I have the “Image elements do not have explicit width and height” issue associated with my logos as below.
Site: https://infoinspired.com/
Header logo 272 x 90px
Header Style: Style 3 – Multipurpose
Footer logo 140 x 48px
Footer Style: Style 3 (logo within Footer Info Content)
Removed the logo and reinserted it. Still have the same issue.
How to solve it?
Best,
Please do these steps
1. disable all tagDiv plugins
2. uninstall all tagDiv plugins
4. re-install all tagDiv plugins again from Newspaper plugins => https://www.screencast.com/t/WLy01lbc
5. activate all tagDiv plugins
Also, make sure your WordPress and plugins are up to date.
Let me know the results!
I have followed your instructions. But still, the issue exists.
  • This reply was modified 5 years by prashanth.
I could solve the Header logo issue by uploading a Retina Logo 544 x 180px. Earlier this field was blank on the theme panel.
I have tried the same with the Footer logo, but not succeeded. I think I am using the wrong image sizes as the sizes are not mentioned on the theme panel.
Current Footer Logo Setting:
Footer retina logo – not using (tried with 280 x 96px, but the issue exists).
What are the current logo sizes for the footer?
Indeed, I did a test, and it seems to be a problem if you use a standard footer. the only solution for a moment is to use a footer template from the Cloud Library => https://www.youtube.com/watch?v=nE51MfLV7hE
Hi, Anamaria,
Thanks for your suggestion.
Best,
