Images and excerpts not aligning in Block 11
Hi – I am trying to publish a post of my website’s Top 25 most read posts (by page views). I am trying to do this with Block 11, to show headlines and an excerpt, the author’s name and date of publication. But the photos and excerpts are not all aligning flush left. Is there a way to fix this? Screengrab of Block 11 photos and excerpts not aligned
Hello INSPIRELLE,
I have inspected your website and I saw that you have some errors on your console and also, it seems that you are using a lot of untested plugins as you can see here -> https://www.screencast.com/t/Ze2L08oa9w Very important is to use the latest version of the theme if you want to achieve best theme results. Also, I have noticed that you are using an old theme version -> https://www.screencast.com/t/jXkpgOLOhQ which can cause a lot of unknown issues. Please update the theme via FTP way according to our documentation here -> https://forum.tagdiv.com/newsmag-install-via-ftp/ Before each theme update, you should make a full backup to your database to avoid losing all of your data.
