Images not displaying in block 7
I have installed this theme in my site http://www.informer24x7.com
however I have a problem in Home page. Im using Block 7 to display posts.
The problem is that some posts dont display the images, and they are there.
If I see the article in other listing like /category, the images displays ok.
Thanks in advance
I have checked your site and the posts that do not show images do not have an image to show. You need a featured image or video for the image to show up on the blocks. Please use this guide and add propewr featured images or featured videos to your posts: https://forum.tagdiv.com/featured-image-or-video/
Alternatively, please enable the placeholders so if there is no image, there will be a placeholder for the block:
http://screencast.com/t/2Y2MBFWn80 ALso make sure your thumbnails are active:
http://screencast.com/t/RWrJene0
Thanks for your reply.
All my posts have a featured image. I create them with WordPress API.
Take for example post 1793: http://screencast.com/t/5bH9d4hS
It has a featured image and its not showing: http://screencast.com/t/3ASS0DOL
Also my Thumbnails are active
I;pm not sure what customization you made and how you implement the images but this is not a standard implementation of a featured image. You use post template 1 but there is no featured image shown on the post itself. I just see an iframe. There is no code for the featured image as well in the browser inspector. The blocks need the featured images to be contained in this css class:
td-post-featured-image
There is no such class on any of your posts including the ones that are showing the featured image on your homepage. I;m not sure how you use the theme api to add a featured image but you need to add it by the standard method of pressing the ‘set featured image’ button and selecting a file from your media library.
We cannot guarantee our blocks will work with custom implementation of featured images.
