Important issue with Review plugin
Hello All,
How to add a “conversion” button in the Review Box or next to it ?
I can’t find this option but having a button at this place is the most important and basic feature for a review conclusion in order to improve conversion. Like “Get this product now!” kind of button.
Where to do this ?
Cheers
The only available review system in the theme at the moment is like this – https://forum.tagdiv.com/reviews-2/ and there is no option to ad a conversion button in the review box. If you want to achieve something like that, it will have to be custom made. This is where the review system is defined – https://www.screencast.com/t/gux3kdDeFMl and where you will have to make the modifications if you choose to implement this functionality. You could also search for some plugins with that capability and try a few of them, maybe you will find one to suit your needs.
