Installing Demos with no loss in settings.
Can anyone please tell me , while changing demos how to revert my settings? I lost my complete setting of the theme
When uninstalling or changing to another demo, all the settings and content imported by the respective demo on installation will be removed and everything will be as it was before the installation. That is way you should not edit the dummy data from the demo to prevent it from being removed. This is mentioned here – https://forum.tagdiv.com/installing-demos/
Each theme demo has it’s own settings and design. You could just reinstall the previous demo, you can not have one demo installed with the settings of another. It also would be best to make periodical backups in case a mistake was made. Please correct me if I misunderstand.
