Intended work flow with Newspaper Theme
Is there a beginning “how-to” for this theme? I clearly don’t know what I’m doing. For example: For the main menu, I use a specific page to display the most recent blog entries, but when I go to a specific blog entry, I have no idea where it’s getting the template to display that actual blog. Maybe a category template? I dunno. The same hold true for the Featured articles menu item. I display a custom page for the featured articles page, then have no idea what template is being used to display an article when one is selected.
I guess the question is, could someone (who has nothing better to do) describe their process? What templates are used to display posts? To display the menu pages? i started using WordPress with a different theme, and ended up using custom hand built pages and a plugin with lots of short codes to get things displayed, but I’m getting the feeling that Newspaper is not intended to used in that fashion.
My site can be viewed at: http://www.hiddenmesa.com
Thanks in advance, and be kind. Oh, and to be clear, I’m not asking for someone to do a lot of hnd holding. I would be very happy if someone could just point me in the right direction in terms of finding the proper, starting documentation. A “how to begin” paper would be great..
Hello donfink,
Please keep in mind that our theme is very user-friendly and has a lot of post templates which can be used to create your own post. You should just choose the template you want from our list. To see all of these, please check our demo preview, here -> https://www.screencast.com/t/V48uGfK64 -> https://demo.tagdiv.com/newspaper/wordpress-news-magazine-charts-the-most-fashionable-new-york-couples-in-2016/ Also, for more information about our post templates, please consult the documentation here -> https://forum.tagdiv.com/post-templates-2/ Also, before beginning to create your website with our theme, please notice that you should start reading all of our documentation and also, you can check our YouTube channel because there we have a lot of useful video tutorials which can help you -> https://www.youtube.com/user/tagdiv.
Thanks for your reply,
The thing is, I am reading the documentation. And I’ve watched nearly all of your videos. I think my problem is that I seem to lack a basic understanding of how a WordPress site is supposed to be used. With my last theme, I created various pages to get the look I wanted in terms of which content to display, then added shortcodes from a plugin to control the loop the way I wanted. With your theme, I believe I’m supposed to use it like WordPress was probably intended, which I never learned.
I’m getting it squared away now though. I made some major breakthroughs over the last couple of days by trial and error, and I’m confident that the decision to buy the most complicated theme I could find was the right one. It’s coming along quite well.
I would like to mention that I am not a fan of your documentation. Most of it reads like a sales ad to me with very little substance. And what substance there is assumes that I know far more than I actually do. The videos are even worse. They’re slick and well produced, but there seems to be very little substance to any of it that I can use.
Please understand that my criticism of the documentation is meant to be constructive. I am using it, as far as it goes, but I think there’s room for improvement in terms of explaining some of the basic concepts used in the theme. It’s possible that what I’m critical about is beyond the scope of what you’re trying to accomplish with the documentation, and I should have entered into this with a better working knowledge WordPress in general, but that’s my view.
As it is, I’m still excited about the kind of site I’m going to end up with because of this great theme.
Thanks,
Don Fink
Hello Don,
I understand what you mean about the docs and videos, but they are all created with the assumption people who use wordpress theme,s know what wordpress is and what can be done through the wordpress settings. If you lack the basic knowledge I would suggest starting with a few basic wordpress tutorials to learn how pages are made, how posts are created and how they belong in categories, and how to build and set a homepage. For the homepage for instance, wordpress provides 2 options. Either a list of your latest posts, or a page you create and select for it. I assume you have the list and do not know where to dfind the settings for it. OPur theme uses templates for all the wordpress specific pages such as the one you use. These templates are found in the theme panel-> template settings: https://www.screencast.com/t/mh1qwGmDX9
Under the wordpress templates, you will find the theme way of setting the default predefined templates used by wordpress. The theme ad’s it;s style to these pages but since they are predefined by wp, they cannot be edited in the page builder. The same goes with the categories for posts.
The standard pages however are built in the page builder like so: https://www.youtube.com/watch?v=N2wGizMz4X0&t=104s
You can set a static page as a homepage from here: https://www.screencast.com/t/nvdvrIAZpY
I hope this helps.
Thanks Bogdan,
Actually, it does help. The Newspaper Theme has forced me into using WordPress in a different way than I had before, and to tell you the truth, it’s working quite nicely. I learn more every day. I was under the impression that I had to use static pages for pretty much everything, probably because of the limitations of the previous theme I was using. I’m switching the entire site over to using categories and category templates, and it’s really starting to come together.
I’m a long way from being a beginner with WordPress, but I think I learned it in the wrong way, which is in many ways far worse than being a beginner. As I’m re-learning to do this in the way that Newspaper seems to want to work, it’s starting to look pretty good.
I have quite a bit of work to do, but here’s what it looks like so far:
It’s already way better than the look of my previous theme, and I’m still learning. By the time I get around to writing a review on this theme, it’ll be pretty close to 5 stars.
Thanks for the help,
Don Fink
Your site is coming up nicely.
Nice job and thank you for your appreciation.
Bogdan B
