Facing same issue as many others. Unable to update/associate an image in the clients logo section. Keeps throwing this message without actual details. Invalid data Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)
Have already checked on allow_url_fopen and its on. Have no other plugins other than the recommendations. Still this isn’t working. Please help.
Same situation here. This theme is really crap. Not much improvements since last version…
Creating header often ends up with those errors popping up from everywhere “Invalid data Current state has involved an issue.”
If you create template and then reopen it, it also often says that it was not created in tagdiv composer or whatever.
It is really shame you still have so many bugs in your newest version of theme. Thinking of asking for refund since this theme is really pain in the ass to use without tons of palm faces.
usually if the error appear when you upload an image in tagDiv Composer, then the allow_url_fopen = On should fixed the problem, also make sure that all theme requirements are set as in our guide -> https://forum.tagdiv.com/requirements-for-newspaper/
If the problem persist please make a full backup and send us an email at contact@tagdiv.com and provide admin login and cPanel. We will take a look. Include a link to this topic in the email and provide as more details and screenshots you can.
Let me know the results!
Have sent you all screenshots and credentials via email. Please check and revert.
We received the emails and will check the problem.
Also please check if you are not using WP Bakery plugin, sometimes this is causing conflicts if you are using cloud templates, please check the plugins you have enable and if this one is enable, disable it and try again.
Ok. Disabled WP Bakery Plugin and then it worked. What’s the root cause and how do we make things compatible? Because WP Bakery Plugin comes as an optional suggested plugin in Newpaper’s own dashboard isn’t it?
Hi, the WP Bakery Plugin is an extra plugin that we provide for the users that do not want to use tagDiv Composer with tagDiv Cloud Library.
For the moment you can use this plugin only if you do not use cloud templates, also it can not be use on the same page where was use tagDiv Composer.
Hope that in coming update this plugin will be more compatible with tagDiv Composer, but with cloud templates I do not think that will work.
Ok Calin. Got it. Thank you for the update. Appreciate it.
