ios slider problem
Hello
When resize browser (firefox,safari) IOS slider (slider 2 column) gets WIDTH:0px HEIGHT:0px as a result, second slide not display
  • This topic was modified 9 years by ihora.
This is not a default theme setting. It could be grabbing the css from a plugin or a third party tool. Our ios slider works just fine on every device:
http://demo.tagdiv.com/newspaper/ios-slider/
Hello
I captured video with the bug in firefox / resize.
Also in mac / safari not seemed from the second slider onwards.
https://www.zipshare.com/download/eyJhcmNoaXZlSWQiOiIwZDQ0OTM0MS1hYjg3LTRjYjktYmQ1Ni1hOGIyNjVhZTg4ZjAiLCJlbWFpbCI6ImtfcGF2bGlkaXNAeXBhaXRocm9zLmdyIn0=
*Windows 10
*Firefox 50.1.0 without plugins
*The video opens with firefox
  • This reply was modified 9 years by ihora.
Thanks for sharing this. I have checked into this and there seems to be an issue causing this. I added it to our list for future updates.
As a quick fix, you can add this code in the theme panel-> custom css box:
.td_block_slide .td_module_slide, .td_block_slide .td-slider{
width:100%!important
Yes it seems to be a js error affecting the ios slider. Unfortunately css will not fix it. sorry. You will have to wait until the development team can take a look and provide a fix for the element.
Sorry for the inconvenience.
I am waiting for your reply.
Do you have any information about our problem?
Please update the theme to the latest version using this guide: https://forum.tagdiv.com/how-to-update-the-theme-2/ and makje sure youy only use the tested and recommended plugins. The issue should not be there anymore.
Let us know how it goes.
Hello
the problem remains
you can see it here
test in version 7.7 + disable plugins
Hello ihora,
Furthermore, investigation, this type of issue cannot be fixed because the js for FireFox Mobile is too sensible and unfortunately, did not find any reliable solution for remediation, sorry!
Sorry for the inconvenience and thank you for your understanding!
