Issue with Block Text Settings
Ive just updated wordpress to the new version and began to have an issue with the WPBakery Block Text. When I try to edit some text in the page, the block text settings popup but the text field is blank and there is no option to edit the text. The General and Design Options also disappeared.
Do you know what should I do to solve this issue?
Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all plugins and child theme ( if you are using ) and let only the tagDiv Composer , clear all cache, deactivate the cache plugin and try again.
Also please make sure that all the settings are like in our requirements, please follow the guide carefully
