Issue with display on admin frontend and final preview on other browser
Hi, I am having problem to figure out how my preview on other browser is different from what appear on my admin frontend view. I am using a firefox browser to manage my backend and the view appears exactly like my theme template but when I try to view it on google and opera it didn’t look the same.
site url: http://www.hoopla.my
view on my admin frontend: https://www.mediafire.com/view/a9e6whc8rlvun41/admin-view.png/file
view on google: https://www.mediafire.com/view/kq7kco321tgkham/google-view.png/file
view on my opera: https://www.mediafire.com/view/ygxz9zkff45r12x/opera-view.png/file
That view is from the mobile theme plugin, when you are using it you’ll need to make sure that your cache plugin has a mobile support (has de possibility to select the right cache that should be delivered). For this we recommend WP Super Cache this plugin has mobile support -> https://i.imgur.com/bAujS5w.png
Another alternative is to disable the mobile theme plugin.
I hope this will help you!
Thanks.That really solved my issue.
