I’m unable to copy exact header for my website even after importing the prebuilt website(newspaper default pro). I’m not able to see my homepage button and when I’m hovering to categories section some kind of glitch I’m seeing this is not exactly same as the newspaper default pro pre built website. also when I’m using footer section in theme pannel there is no option is visible to me so that i can edit i’m just seeing two options no template and default pre built template.
Please Help I don’t know how to attach screenshot. Please help me i want to correct it as soon as possible
You need to go to the Theme Panel -> Header/ footer and assign the cloud templates https://i.imgur.com/COsz8eS.png, you can edit them with tagdiv composer -> https://i.imgur.com/CLfc37b.png https://forum.tagdiv.com/header-manager/ -> https://forum.tagdiv.com/footer-templates/
Thank You and i have also two more queries
1. Is there any type of plugin or feature in newspaper theme which can automatically share my articles directly to my social media accounts.
2. How can I optimize these theme to increase the website speed for both mobile and desktop. my current score is below 60 in both devices even after amp installation
Those can be done with custom work. You can request a quote here https://tagdiv.com/web-development-services/
I had a conversation with the custom work team, and they indicated that achieving this can be facilitated by utilizing a dedicated plugin. They recommend using a plugin designed for this purpose rather than developing the functionality from scratch -> https://wordpress.org/plugins/social-media-auto-publish/ -> https://www.mentionlytics.com/blog/10-best-tools-auto-share-posts-social-media/
The mobile theme comes with its own templates for page, post, category, etc so your current templates from the desktop theme will get converted to the mobile theme layout, the page content is made without builders in mobile editor => https://www.screencast.com/t/xbgZG8kH also, the options that are provided to edit the mobile theme version are limited (this keeps the things simple)).
So, if you want to use the cloud templates, then you need to disable the mobile theme and AMP plugins, and then use the responsive version.
You can disable the mobile theme plugin on the pages from the Gutenberg editor using the following option => https://www.screencast.com/t/axXRJsWby
Also, please check this topic where I explained each mobile version -> https://forum.tagdiv.com/topic/mobile-version-not-working-properly-2/ -> https://forum.tagdiv.com/topic/amp-pages-not-working-well-with-this-theme/ and choose what mobile version you want.
Unfortunately, I can’t see your screenshot.
We recommend using the mobile theme plugin with amp -> https://i.imgur.com/EgTXw8j.png (on amp let the Transitional option be selected), in this way, the amp will have the mobile theme layout, and you can control the elements that you want to display using the mobile settings.
Please let me know what you have selected here -> https://i.imgur.com/WA5U5uC.png
I want to add Google News Follow Button on my Home Page & on every Post. How can i do it
https://www.universitytimes.in/wp-content/uploads/2022/09/follow-us-on-google-news.png“>EXAMPLE(Button)
