In Block 4, while Unique article is enabled on the Home page, and pagination is set to Lord more, result of clicking on “Load more” repeats articles on the same page.
See settings https://gyazo.com/227e9059c9790d7eabf7d07341e2a79c and result https://gyazo.com/d8ee5ee2f8aa1f9b9f7a58875f996a09
Hello bhadrabalaram,
Unfortunately, the Unique article does not work with pagination, sorry! As an alternative for you is to use offset option for each block and these would be set according to this documentation here -> https://forum.tagdiv.com/unique-articles/ -> https://forum.tagdiv.com/offset-feature/
Hope this helps!
Thank you for the message!
Ok I tried that too. Mind you, I am talking about the duplicates appearing WITHIN THE SAME BLOCK and not in another one. https://gyazo.com/b40cf262c298d416009868eb711fd899 with this settings https://gyazo.com/244e6f69804b3683b2d953aff387a42d
If you are using Unique Articles, please keep it disable and also, please check the type of your sorting to be by LATEST and check again the results. I have tested on my side and everything works fine.
Hope this helps!
But if i disable Unique article then I will need to use Offset on all blocks…right?
Yes, your offset number will have to be equal to your number of the posts which you will display on your block, like this -> http://screencast.com/t/YxMygSeP
