Issue with “Posts Loop” block and category template
Congratulations,
1. There is a problem with the selection of the category template, for some reason another template is not selected (https://imgur.com/a/89n3Uxn).
2. When some records are excluded and when several records are skipped in the “Posts Loop” block, when the next news is automatically downloaded, they begin to repeat (https://imgur.com/a/SS9maCN).
Please try to assign the category template from the Dashboard -> Theme panel -> Categories https://app.screencast.com/ebAqIdxBvDx3Z
You can use this option: https://forum.tagdiv.com/unique-articles/, so you won’t see double posts anymore.
1. Thank you, everything worked out.
2. This problem occurs on tag pages and category pages. If it were a static page, this option would be there, but in my case, these are non-static pages and I can edit either tags or categories where there is no such option. Is it possible to fix duplicate posts in some other way?
View post on imgur.com
Unfortunately, no. You can only fix it from the offset value: https://forum.tagdiv.com/offset-feature/. Please try to use a flex block instead with the special filter for tags/categories: https://forum.tagdiv.com/flex-block-settings-guide/
The problem occurs regardless of which unit is used. Shifting records works until exclude records is added to the Exclude Post IDs: field and I need to simultaneously exclude some records from a block and shift the display of records by a certain amount. Please let me know if there is a solution, if there is no solution yet – take this issue into consideration. Thank you
We want to investigate your issue.
Please get in touch with us via email at contact@tagdiv.com and provide the following:
– admin URL and credentials
