I’m trying to run responsive, no mobile theme, no amp. I’m facing an peculiar issue where the theme displays fine on the home page but doesn’t display properly on any posts or pages.
1. When mobile theme plugin disabled, posts show h1 text in place of graphic logo, and footer doesn’t display or displays oddly because I’m seeing @newspaper wordpress theme by tagdiv on the footer.
If I try to edit this footer it tells me you cannot edit this type of footer.
I’ve cleared cache a bazillion times, What could this be?
This topic was modified 1 year by
signals.
If the footer displays a text that can not be edited (when you hover it), then you are using a standard header, not a cloud header/footer, and it can be edited using the theme panel settings. In case you want to edit it with the theme builder, use cloud templates.
TY for getting back. Yes I understand that a cloud footer can be used but that does not seem to solve this problem. If i try to edit it with theme builder it gives me an error.
I have disabled both mobile and amp but the regular theme, in responsive mode does not seem to display properly on mobile. How do I solve this?
Yes, for this please use our email address contact@tagdiv.com provide there the screenshots and include the link of this topic to identify you faster.
