Issues with building home page
Hi!
I am having issues building the home page. For instance, it won’t allow me to delete blocks when I press delete and nothing shows to the right or no header.
I also can’t get plugins button to disappear either on top right of screen. Also, when I try and save page it says saved but it won’t actually save.
Is someone able to respond to me please?
I also can’t delete rows when I press delete. So many issues you people need to fix!!!
Also, now I can only insert items on page builder by adding bottom up and not top to bottom. Why all of these issues?
Hi frudy,
Please do not replay multiple times in topic, will only delay the time until you get the answer, we answer in topics from oldest to newest.
Also most of the problems that you reports are usually made by untested plugins that can be in conflict with our theme, please deactivate ALL plugins except tagDiv plugins (theme plugins), also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also make sure that you or your host do not have some security module or a firewall that is blocking the theme or theme plugins.
Let me know the results!
Good Morning! I reviewed everything and our hosting support replied and said: the theme Newsmag and the plugins Ad Ace and TagDiv Composer have not been updated for best compatibility with the latest version of WordPress (version 5.5).
I tried to upload what came with your package, but it continues to fail. How can I get the latest updates? I even tried manually and it failed as well–
Hi frudy, if you are using the last version of WordPress, v5.5 then you must use the last version of Newsmag too (v4.9.5), only this will work properly.
For this you need to update the theme and you can use our guides from here -> https://forum.tagdiv.com/newsmag-how-to-update-the-theme/
If there are some problems, please provide some details about theme and some screenshots.
