Hello: please look here: https://ijndevsite.wpengine.com/home-page-test/
and see my questions here: https://drive.google.com/file/d/17dG1Q-NAZvyk6dsLTVgA__55YbkLr8WN/view?usp=sharing
I don’t have access to the Google Drive image -> https://i.imgur.com/JRuk5oF.png.
Sorry. Please try this: https://drive.google.com/file/d/1tyQJy5K-ArxmmqaV8-o1qDTy-doBb9cR/view?usp=sharing
Please check the padding https://i.imgur.com/3pATv4T.png for the meta info
You can use the module divide and will be equals-> https://i.imgur.com/rskbDnE.png
I saw you also set the color for the menu and changed the block for posts -> https://i.imgur.com/rbsYnz0.jpg -> https://i.imgur.com/mVLadrf.png.
I’m glad you figured it out.
Also, you can add the weather from tagdiv Composer https://forum.tagdiv.com/weather-widget/.
