Job Hunt PRO approved post
Hello, I have Job Hunt PRO installed on my website and I have the following problem:
Whenever someone submit post (job) it has to be approved by me which is perfect, but as soon as I approve it it gets posted under my name not the person who actually posted it, how can I fix that ?
Hello @sotirow96!
Check this guide and set up the submit button: https://forum.tagdiv.com/create-frontend-submission-form/
Checked it, it still does not work, when I (as admin) approve an post from a user the post gets added to my name not to the user who posted it.
Hello @sotirow96!
I’ve tested on my end, and I can see the user is the author that appears in Jobs -> All Jobs. Also, the user can see in my account -> job listings the jobs created by him only.
You can enable the author of a CPT from ACF: https://app.screencast.com/B5LCgkQgcMwW4
Yes now its working, the other problem I am facing is that the default CPT template is not the one I want, it is always this one:
Screenshot
How can I make the default template for this post type to be different than the default ?
Hello @sotirow96!
Please check in the Cloud Templates if the CPT templates are set as global.
Yes, thank you this worked.
