I have been battling with this challenge since I bought the theme.
I tried to make Flex Block 2 at the top of the website’s homepage show latest post, but it does not. I have changed categories and filters but still couldn’t show the latest post as the main big picture to be followed by subsequent posts.
We have been having the same issue with flex block 2 as well, it will only show a post if all categories is selected, but not the one we would like to display.
Blocks are all the same in terms of filtering and sorting, only their design is different.
If a block doesn’t show the latest post or posts, then it could be because it has an offset -> https://forum.tagdiv.com/offset-feature/ That’s the first thing to check. An offset will make a block skip a set number of posts, this is helpful sometimes.
Please check if the block has an offset.
Hello
Thanks, I have worked on the offset. It’s okay now.
However, I have another challenge with the top of the website’s homepage, which I have not been able to fix for a while now. How do I go about it?
I want:
1. The present first column becomes the third column
2. The present second column (the column with the Big Picture) becomes the first column
3. The present third column becomes the second
The easiest way to do that is like this:
Click on the row that contains those columns and activate this option -> https://prnt.sc/7Nah0MzBjn3b
On the first column set the order to 3 -> https://prnt.sc/_s30ntkzhXwj
On the second to 1 -> https://prnt.sc/tNrLynDAhsT7
On the third to 2 -> https://prnt.sc/0pjTrwJATJOc
And on the fourth to 4 -> https://prnt.sc/xiOJQXlqo0IB
Then it should look as you want. Please try it.
As a note, on mobile please set the row to it’s initial layout -> https://prnt.sc/3R8ImUF0s6fk
Or, if you want to change the order on mobile also, set it to this one -> https://prnt.sc/V1YaRnf9tZJi
