I am sure he wants to enable this panel: https://jmp.sh/i7TJpp8
And I need it too !!!
Sorry if I didn’t make myself clear. The problem is I have this CPT called “Entities” and, when I access the Edit Post page to edit one of them, I only see the Sidebar Settings, whereas for normal Articles I see both Page Template Settings and Sidebar Settings. I would like to know if there’s a way to show the Page Template Settings also for CPT. Attached you can find two screenshots so you can see the difference. The first one is the Posts and the second one is the CPT
Please check the Screen Options from that post ( https://www.screencast.com/t/JgTbS0Qte9D ), you can have some plugins that interfere with the theme; also if the “Entities” is provide from some plugins ( example https://www.screencast.com/t/St9FoGK4rz ), those don’t make part of theme.
You need to edit a file from includes>wp_booster>wp-admin>content-admin>content-metabox>te_template_settings.php
https://www.screencast.com/t/QFv0k12JEp
But it’s possible to won’t work as you expect, that’s why was been hide.
Also you can read How to create a custom single template in Custom Post Type Support documentation : https://forum.tagdiv.com/custom-post-type-support/
Hi, I followed your instruction and modified the code in order to show the layout settings on CPT (look at the code here https://pastebin.com/PGZKJz6z)
Using this snippet I’m able to display the layout settings panel on the Edit page but it doesn’t work. In other words, the template doesn’t get assigned to the post. Any help?
Have you try to make an Individual post settings for custom post types:
Unfortunately our theme is limited when is come to CPT , maybe you can fine a plugin that manage your requirements.
Hi, maybe I didn’t explain myself well in the previous posts. What I need to do is switching the template files for my CPT the same way I do it with the normal posts. Is there a way to do that? If not, can you please point me to the file inside the theme structure where you assign the different templates using the layout settings panel? Thank you
Check how to create a custom single template for your post type.
-> https://forum.tagdiv.com/custom-post-type-support/
Please try to test our plugin td_books
https://www.screencast.com/t/gCGukYBJ
