License Problem
Hi Sir ,
I want to theme license o my domain I don’t know I activated license of Newspaper theme on how much domains and which they are I want to remove them & Use It only in my new domain.
So, Remove all old domains which are using my license. I will add my own which site I am working.
Any one is here ?
You can use a license key for one single product, but if you want to move the theme to another website or change domain/migrate, you’ll need to reset the license key from that website: https://www.screencast.com/t/Zt12bpyX and remove the theme (delete), in this way the license will be available for the new website and you can use the theme without any problems.
According to Envato license terms, a theme can be used for a single end product (website):
– https://themeforest.net/licenses/standard
– https://themeforest.net/licenses/terms/regular
