Link Blocks within a same page
I hope this question is not too stupid ..i am trying to link two blocks that aims to display same kind of posts but with a different look…(lets say big picture for the last 5 posts, and only titles for the olders)
Assuming i do have 20 posts …BlockA showing 5 posts in a certain way with filtering on a specific category, BlockB showing remaining posts of the same category..i do not know how to do that …
Both blocks are showing same posts categorys, only BlockA showing ajax filters …how BlockB can know that BlockA is filtering a specific category ?…is there an easy way to do that ?
Should i create a new block instead merging BlockA and BlockB ?
Thank u for your hepl and support
Hello stephane.roy,
I guess that here you are referring to the unique posts. So, if you want to display this, please notice that you should try using the Unique Articles or Offset feature from Blocks when you create your pages. To avoid the duplicate posts, please check the following useful tutorial here -> https://forum.tagdiv.com/offset-feature/ -> https://forum.tagdiv.com/unique-articles/
If is not what you mean, please provide more details and some useful screenshots so I will be able to provide a more accurate response.
Yes this is basically linked to unique articles. The feature works well for me as long as i do not filter the articles that i want to show in the page using the first block…
With no filter ..all blocks display the articles in the way they are supposed to show them..
My issue comes when i want to filter the articles with categories or whatever feature. Only the first blocks apply the filtering and the remaining blocks in the page are still living their life by themselves …
I would like to ensure that if i filter a specific content on the first block of the page..the remaining blocks under are applying the same filtering and will handle the offset in the appropriate way …but i do not succeed to make the other blocks from the page to react or linked to the filtering of the first block …do you se what i mean ?
Thank you for your help and support,
Stephane
Hello stephane.roy,
I have tested on my side the Unique Articles on pages and everything seems to work as expected, without any problems. For example, I have added two blocks filtered by different categories and it did not saw duplicate posts. Try to save all of these settings and check the results. If the problem is still there, please provide some useful screenshots with this problem and also, provide your website URL.
