Is it possible to load this look/feel/setting setup https://demo.tagdiv.com/newspaper/ into an existing website – easily and fast? I’m hoping to not have to go section to section to set up the same look and feel. Thank you!
I did the install demo, no content option but still looks nothing like the newspaper demo – it’s missing the sidebar, etc.
That is the default theme demo – https://forum.tagdiv.com/installing-demos/
Pages will be provided when a demo is installed, with content – http://prntscr.com/nju4q3
Then the demo homepage will be imported and you can edit it with the composer, and configure the elements in it to show the posts you want
– https://forum.tagdiv.com/block-settings-guide/
Also replace the other demo elements with your own (logo, menus etc).
If you want just the homepage, I can provide you with the code for it, here it is
– https://pastebin.com/6hejgpuE
You can enter this code in a new page – http://prntscr.com/nju7gc then edit it with the composer and configure it. The default demo doesn’t have many specific elements, it is the simplest demo.
Let me know if you have more questions, or you need help.
Hi Simion C.
I’m also trying to setup a homepage in an existing website just like the demo https://demo.tagdiv.com/newspaper_week/ but having no luck so far, can I get hold of the code for the homepage of this demo, please?
@nunomura There will be more demo homepages and pages added in the cloud library in the future, currently only these are available for import
– https://cloud.tagdiv.com/#/load/Homepages
– https://cloud.tagdiv.com/#/load/Pages
I can provide you with the code for the news week demo homepage
– https://pastebin.com/cQZtYz15
Enter it in a new page and edit it with the tagDiv composer, configure it as needed.
Let me know if you need help, or you have more questions.
