Load the newspaper theme and plugins and Memory and I/O max out straight away
Recently purchased the full newspaper theme but when I try to install the theme and enable the plugins (there are approx 10 articles just to allow me to develop the site with very few other plugins installed), the website returns a 503 error.
Investigation in the cPanel shows Physical Memory maxed out at 512MB and I/O maxed at 1MB.
Can anyone confirm why this would be the case (never had any issues with other themes before) and what the minimum specs are to use this theme?.
Thanks,
James
To add: I have reviewed the requirements link that always gets referred to and have adhered to the requests in the guide.
I have worked out that if I activate ALL of the theme plugins with the exception of “TagDiv Cloud Library” the site is available and no max out issues.
However, the second I install/activate the “TagDiv Cloud Library” plugin, both Memory and I/O max out and the site returns a 503 error.
Hi jalovell78,
Also please check the topic from Satwik, this should fix the problem.
