I applied block 7 to our home page and enabled pagination. When the site loads on desktop and mobile, the thumbnails are dull and low res compared to the next set of thumbnails. When I click on the next page, the thumbnails are okay. Then when I click back arrow, the thumbnails are back to normal. There are no other issues with the other blocks’ thumbnails. Is this a bug?
Hello @vlad. Pls see https://mypope.com.ph/ and review block ‘Vatican updates’, top right block on desktop browser. Or first block in mobile. Thank you!
Hello !
Please make sure that you are uploding your image full size as you can see it here: https://www.screencast.com/t/Oxue274e
Thanks for the reply. However, that option is not available when adding a featured image. It doesn’t make sense that all the other blocks with thumbnails that use featured images are fine. Only the first set of images in block 7. Is there another option we can test? It looks horrible on mobile until you arrow right, then arrow left again.
Thank you
I just check the problem and for me is look normal, but if you want you can replace the block 7 with a flex, if you want you can import it from cloud https://i.imgur.com/t4Frua4.png -> https://i.imgur.com/ytBC7J3.png -> https://i.imgur.com/xdE7k9a.png on flex you can choose the image -> https://i.imgur.com/g0zgqHG.png -> https://forum.tagdiv.com/flex-block-settings-guide/
