Main Menu Problem
I need urgent help. I am explaining to give an example. My site has categories such as Life, food, travel and agenda and their subheadings. I edit the life page and filter accordingly, but when I enter the food page, its page turns into the life page. How can I solve this problem?
For each category, on the flex block there is a special filter for the current category, which dynamically displays the posts from that category within each category -> https://forum.tagdiv.com/flex-block-settings-guide/
The Posts Loop automatically filters the posts depending on the cloud template you set (for example, on the category page, there will be posted posts from that category) https://forum.tagdiv.com/posts-loop/
Please check the block with “No posts” and delete it the offset number; leave it empty with no space or value: https://app.screencast.com/Gh9jDf6t0XtLS
I looked at what you said and Offset posts seems empty for me too. I have set up a category and subcategory structure. For example, my main categories are called; Agenda, Life, Food, Astrology and then under these categories there are their own subcategories. For example, there are desserts, pizza, etc. under the Food category. I select food from the filters section in the food category, but when I enter life or astrology, food also appears. I cannot filter the category under each main category.
You need to set the special filter with category – current category -> https://i.imgur.com/U9YF80Q.png -> https://forum.tagdiv.com/flex-block-settings-guide/
Thank you
