Major problem with my site
There is a major problem with my website.. https://lazonemph.com/ user : invite password: invite
Everything is messed up.. What should I do ?
Should I reset my theme? Thank you.
I could give you the access…
It seems to be a problem with the CSS, everything has changed. Black Headers are not the one’s I have chosen, the background is at the top of the page, footer is also different. Hope this is not something easy to solve.
Everything has been disabled… cache is empty.. Still not working.
I have remove custom code also.. I don’t know what to do, little desperate right now.. Please help me!
I have made some modification on the CSS styles.. Can I go back to the first version?
You can simply replace the theme files as you would when you update. Please use this guide: https://forum.tagdiv.com/how-to-update-the-theme-2/ and choose the wordpress method.
Then remove any custom code from the theme panel.
