Manual place related articles
Is there a way to maual place realted articles? In my case I use a “bottom widget”. And when I activate realted articles in the theme menu, this section will show up on bottom of my site, underneath everything I got in the bottom widget.
Any manual code I can place?
The theme related articles section will always be at the bottom of the post page, only the comments will be below it when enabled.
That is where it is supposed to appear and defined in the post template files
– https://www.screencast.com/t/KFd4EJRg
Maybe modify the location of that code in the template, move it higher and see where it appears then.
Make the modification for the post template you want (Ex: post template 1 – > loop-single-1.php).
For the new cloud post templates everything in the post template can be rearranged with the tagDiv composer.
– https://forum.tagdiv.com/tagdiv-cloud-library-plugin/
But for the predefined ones only though template file modifications it will be possible.
