max_ececution_time + max_input_vars edit??
These two items need to be modified, which file should I edit? Please send me the screenshot you actually applied, we don’t really need a “reference link”.
https://forum.tagdiv.com/requirements-for-newspaper/ <- nono
No need. I understand. I need to know which column and location to insert the code from which file.
The actual screenshot is very helpful to me.
There are more ways to set those requirements, for example you can check this guide for how to set theme using the options from cPanel https://chemicloud.com/kb/article/how-to-increase-the-max_input_vars-limit-in-cpanel/ also you can set the code in php.ini file (if exist) or in .htaccess at the end of the last content from the files.
I hope it will help you!
cPanel login I don’t know how.
The administrator is connected.Why don’t you fix this?Editing isn’t happening, is editor at the moment I can’t solve this problem.
Usually, those settings are handle by hosts, but we can try to set the theme requirements for you, but only via email, for this, please send an email with wp-admin and cPanel for the website where you can not manage to set them.
Carlin host does not give the cpanel ID password. What should I do?
Then at least a FTP access, because without having access to the files on host I can not help.
Or you can ask the your host to set those requirements for your website (those are part of host).
-> https://stackoverflow.com/questions/9973555/setting-max-input-vars-php-ini-directive-using-ini-set
-> https://chemicloud.com/kb/article/how-to-increase-the-max_input_vars-limit-in-cpanel/
